Identify Unique values from multiple attributes
  • November 13, 2013
  • 5 replies
  • 389 views
Hi there,
I'm wondering if anyone would bo so kind as to help me with a little issue I'm having...
I have a dynamic ESRI shapefile source folder, with multiple shapefiles within.
All of these features have 1 thing in common, namely that they all contain the following attributes:
CREAT_USER
EDIT_USER
ATT_USER
Now these attributes all contain actual names, like Jeff, Pete, etc...
Ok, so lets say In CREAT_USE has multiple entries (inside multiple features, as this is a folder I point to and all shapes within get read) of the following names:
-Pete
-Jeff
EDIT_USER has:
-Jeff
-Susan
ATT_USER has:
-Susan
-Pete
-Rick
I want a summarization of all the possible values contained within all the source shape files. I don't care for the counts that these entries occur, so I simply want all the "possible unique values", filtering out all duplicates. Example output:
-Pete
-Jeff
-Susan
-Rick
Please feel free to ask more questions if this doesnt make sense.
Keep in mind that even though CREAT_USER, EDIT_USER, and ATT_USER will always remain like that, the values (aka the names) could differ each time, depending on what source data it's run on.
Thanks in advance,
Robbie
  • November 13, 2013
you can split your data flow in three and in each branch you rename each attribute to the same name, e.g. USER. Then you use a DuplicateRemover on USER in the end. Like this:
David
fmelizard
Forum|alt.badge.img+19
  • November 13, 2013
With the DuplicateRemover you can point to multiple attributes and get the unique attribute values.
Itay
  • November 13, 2013
@Itay: if you use multiple attributes in the DuplicateRemover, does that not return all the unique combinations of these attributes, rather than a list of all the occurring attribute values?
David
@David,
Your instructions worked beautifully. Almost feel embarrased at how simply it is.
And I did in fact try the duplicate remover on it's own, but that did not give the correct results.
Thanks a lot!
fmelizard
  • November 13, 2013
@David, right you are! forgot about that....another option would be to create a list form all your attributes and use the ListDuplicateRemover but thats an overkill....
