Identify exact attribute values changes when comparing two sets of data.
  • February 14, 2023
  • 20 views
sperez
Hi All,
I need to identify exact attribute values changes when comparing two sets of data. The datasets have the same attributes but some attribute values are updated overtime and I need to identify which ones. I have been trying workflows with feature joiner and ChangeDetector, but I have to compare the datasets several times, discard attributes that remain the same until I identify which attribute value changed. I would like to find a more efficient way to identify the updates, any suggestion? Thank you
Best answer by ebygomm
If you enter a List Name in the ChangeDetector
imageYou'll then get a list added to each updated feature which details which attributes have changed and their original and revised values, e.g.
Forum|alt.badge.img+38
  • February 14, 2023
sperez
  • February 14, 2023
That worked, thank you very much ebygomm :)
