ID for spatial relations
  • Oct 9, 2018 10:38 AM UTC
  • 59 views
I have a set of data in the form of closed areas:
I need to find a relationship between them (with a Spatial Relator or NeighborFinder) and then give the same ID for the related areas(the candidate receives the base id) or at least have a tabular summary of id plotted areasThe requestor and Supplier have separetly id list.
Forum|alt.badge.img+54
  • Oct 9, 2018 11:02 AM UTC
There is a custom transformer - ListCombiner - that can be used with the list generated in the SpatialRelator and the original ID field to create a group attribute
grouping-polygons.fmwt
  • Oct 9, 2018 11:34 AM UTC
could you present what if the Requestor and Supplier have another id?
Thanks a lot for your help
