Iam using FME desktop 2022.1 Is there a way to get the name of a transformer via a parameter value?
  • Sep 8, 2023 9:37 AM UTC
  • 117 views
essb
In the same manner as I can get the name of the workspace via the $(WORKSPACE_NAME)
Trying to make it easier to bugfix scripts if they fail or get terminated by a terminator transformer. The message is then sent to a teams-channel.
nielsgerrits
Forum|alt.badge.img+67
I like the idea, but I'm not sure if this is possible.
How I do my server logging:
  • AttributeCreator downstream of the outputport with a "log" attribute, where I describe the TransformerName (like "Tester_02 Failed") and a description what went wrong ("square has 6 points which is not ok").
  • Add timestamp.
  • Collect and merge all logmessages.
  • Send collected log to channel. In my case, this is email.
essb
  • Sep 8, 2023 11:07 AM UTC
  • Add timestamp.
Hi thanks, that's what i'am doing right now but the lazy person in me wanted a faster way :)
nielsgerrits
I understand :) lazy is good. Let's hope someone with a better idea chimes in.
kailinatsafe
Forum|alt.badge.img+24
Hello @essb​, I was thinking similarly to @nielsgerrits​, the logfile may be the best option. You could also try the LogMessageStreamer, however, it looks like you'd still need to parse the transformer name from log.message (eg. Creator_XML_Creator (CreationFactory): Created 1 features). Hope this helps, Kailin.
