I would like to transform a GeoJSON link into a line feature
  • May 25, 2021
  • 100 views
Hello everyone,
I'm currently trying to make a path from a GEOJSON "link" which was return from a HTTPCaller. Is there any way to transform the link below into a line feature?
Thank you in advance.
This, below, is the GeoJSON file in question.
https://docs.google.com/document/d/1-H6F53Z3Mpu9qmOLQwvifWVPuG7xgjtk4aekHyG1nUU/edit?usp=sharing
nielsgerrits
Forum|alt.badge.img+67
This is quite doable.
  • Put a the response in the JSONFragmenter and fragment the steps. JSON Query:
  • Individual segments
json["routes"][*]["legs"][*]["steps"][*]
  • Complete route
json["routes"][*]
  • Flatten Query Results into Attributes and expose the attribute "geometry".
  • Use a GeometryReplacer to generate the geometry from the attribute "geometry".
  • Set the correct CRS, looks like it is WGS84 / EPSG:4326.
The hard part is to find the correct JSON Query. The easy way to do this is to safe the JSON repsonse to a file, set the JSONFragmenters Input Source to File and then hit the "..." button to see and select in the structure.
2021-05-25_14h50_47Then switch back to JSON Attribute and select the response body from the HTTPCaller.
Added a sample workspace template.
Thank you Niels, much appreciated!
