I want to create slope from DEM using Raster Slope Calculator, the transformer won't give me the new "band 0" values.
  • December 3, 2022
  • 13 views
When I run the tool the "Band 0" values are staying the same after the reprojection transformer is run, any tips to get the new values for "Band 0"?
kailinatsafe
Forum|alt.badge.img+21
Hello @ktmoynahan​, after you run your dataset through the RasterSlopeCalculator, Band0 should represent the slope. If you try to reproject the new/slope raster, the band values should be unchanged, but appear in a new location (assuming a non-vertical reprojection). If I've misinterpreted your question, please let me know and consider adding a workspace or photos to help illustrate the issue! Hope this helps, Kailin
