I want to convert the obj model with map coordinates to the glb model with local coordinates (0,0,0).
I'm converting an obj file to local coordinates, glb.
Running one obj file in FME will take you to the desired local coordinates.
But when I run thousands of obj files in FME, they don't move to local coordinates (0,0,0).
I want to move thousands of obj files all to (0,0,0) at once.
For reference, I activated move to local coordinate.
featuremichael
Forum|alt.badge.img+8
hi @hn35987,
then try to run, a workbench in a batch process, where every single obj file will be converted.
1.) Make a Workbench File, that works for your process.
2.) [this part works this way when all of your obj files are in the same folder]
At first get all fme_Basenames of your Obj files. I Like to get a list (for the batchfile process) with the Reader (Text) and insert all of my files, then in de Navigator Menu on the left side, Set for the Text-Reader [Parameters: Features to Read → Max Feature to Read: 1) - Then under the [User Attribute] for the Text Reader, deactivate “text_line_data” and activate under the [Formate Attributes] = fme_basename  then Inspect the outcome and send the basenames in an Texteditor oder Excel-Sheet
3.) Open your workbench in an Text Editor:
Example Textline to Textline:
Bring this in a Linestring:
 3.)a)
"C:\Program Files\FME2023.1\fme.exe" D:\OUT\textline2textline.fmw --SourceDataset_TEXTLINE "D:\a.txt" --FEATURE_TYPES "" --DestDataset_TEXTLINE "$(FME_MF_DIR)b.txt"
Import this linestring to Excel and get the “Basename[a&B]” from SourceDataset and DestDataset renamed with your Basename
Like This:
4.) Save your Work into an Textfile and clean up the spaces to a clean string like in “3.)a)
save it as a batch file and start the batch process.
Greetings Michael
jasperwis
Forum|alt.badge.img+15
  • March 14, 2024
Or a FeatureReader (Directory and File Pathnames) to find all obj files and a WorkspaceRunner (Wait for job to complete = Yes)
featuremichael
I didn’t know that 🙈 but I need my option often for automatic tasks 😎✌️
