I want to convert 3Dsolids (dwg) to a shape. But the shape is to complex I just want the boundary of the multisurface. How can convert these multisurfaces to a boundary? Thanks
  • Feb 19, 2022 12:00 AM UTC
  • 78 views
Best answer by pieterso
That is more the other direction
I have done a few steps
Geometryfilter with surfaces
2Dforcer
Surfacefootprint
Then I get my wanted result
Thanks
jovitaatsafe
Forum|alt.badge.img+11
Hi @pieterso​,
Have you already given the SolidDissolver a try? It's a new official transformer in the FME 2022 betas that could simplify the complexity of each object by dissolving common boundaries to create larger solids.
You might want to experiment with the Group By option in the SolidDissolver as well depending on what your data looks like. For example, if all your solids share a boundary it'll become one output feature, so if you want to separate them you might need to group by an object or entity ID.
  • Feb 21, 2022 8:15 AM UTC
2Dforcer
Surfacefootprint
Thanks
