I'm trying to use PythonCreator to process and Analyze some data, and my results are in a Pandas DataFrame. There's any way to convert that table to features to use in FME? Thanks for your help
  • February 17, 2021
  • 6 replies
  • 164 views
  • February 18, 2021
If each record in the DataFrame corresponds to an FME feature, then it should be a simple matter of iterating over the DataFrame, create an instance of FMEFeature and set the attributes (and perhaps even the geometry) before outputting the feature. For example:
# Assuming df is your DataFrame object
for index, row in df.iterrows():
    f = fmeobjects.FMEFeature()
    f.setAttribute('my_attribute_name1', row['attribute1'])
    f.setAttribute('my_attribute_name2', row['attribute2'])
    self.pyoutput(f)
  • February 18, 2021
    self.pyoutput(f)
Thanks for your reply.
I've iterated over the dataframe in every way possible, and I've tried yours, and still have the same error: "TypeError: Could not convert attribute value to a supported attribute type", all my records from the DF are floats. Any Idea what I do wrong?
jdh
Forum|alt.badge.img+28
  • February 18, 2021
You can try casting the attribute value to string to see if that works.
I normally encounter that error when the data value is a list.
  • February 18, 2021
Yes, that worked.
Thank you all for your replies!
  • February 18, 2021
Are you sure it is a standard float and not e.g. numpy float32? The fmeobjects API only knows how to work with the basic Python datatypes such as str/unicode, int and float (and Python lists if you specify an FME list attribute).
You could try to simply cast the value to a regular float, I'm suspecting it would work.
Tip: you can find the exact type of any object by doing
print(type(my_object))
Example:
>>> npfloat = numpy.float32(123.0)
>>> print(type(npfloat))
<class 'numpy.float32'>
>>> stdfloat = 123.0
>>> print(type(stdfloat))
<class 'float'>
See also https://note.nkmk.me/en/python-type-isinstance/
  • February 18, 2021
You are right, it's was numpy.float32
Converting it to standard float worked as well.
Thanks
