I'm trying to create point feature class in File Geodatabase. I'm getting an error when I try to write to a file geodatabase: An error occurred while attempting to convert the '' component of a date....
  • Dec 21, 2022 9:41 PM UTC
  • 154 views
I'm able to create a point shapefile successfully.
ctredinnick
Forum|alt.badge.img+22
  • Dec 22, 2022 5:37 AM UTC
I get that sometimes when reading data from SDE, writing to file GDB. A workaround is to add a AttributeTrimmer on the date attributes, which will remove any invalid chars, reset encoding, whatever the actual issue is.
  • Dec 23, 2022 3:18 PM UTC
@ctredinnick​ Thanks mate, this was a big help.
fchevaillier
  • Aug 31, 2023 7:26 PM UTC
@ctredinnick and @robeesafe I am getting the same error, but the AttributeTrimmer is not resolving it. Any other ideas?
