I'm looking on how to add attributes to a raster of points, based on their neighbors
4ntoine
Forum|alt.badge.img+3
Hello
I'm currently transforming a GeoTiff in a point raster using centerpointreplacer. I have a grid of points every 100m.
The next step is to add 8 attributes for the 8 neighbours (or less if the point is on a border) and in each attribute set the slope from this point to the neighbor [in %].
I have z values for each point, I don't know how to get the distance between 2 points and how to add the attributes according to the neighbors.
Maximum distance for neighbors: @sqrt($(Resolution)^2 + $(Resolution)^2) * 1.1
20231212_110110
Thanks,
Antoine
Best answer by joepk
I'm not entirely sure if I understand your question correctly but I think you could use the NeighborFinder for this. Set it to Candidates Only mode.
You could set maximum distance to 100m (or 101, not sure) and generate a list attribute on each point, in which you gather the attributes of interest of the 8 (or less) surrounding points.
You can explode the list attribute using the ListExploder for further analysis/ease of visualisation.
Hope this helps.
joepk
Forum|alt.badge.img+20
  • December 12, 2023
Hope this helps.
geomancer
Forum|alt.badge.img+47
  • December 12, 2023
It may be easier to do your calculations on the original raster. Have you looked at the Raster transformers?
4ntoine
  • December 12, 2023
Thank you for your reply. I have looked on how to do this with raster transformers, like the RasterSlopeCalculator, but it "only" gives the maximum rate of change in z in the cell, and I need to hav the slope for all 8 directions
4ntoine
  • December 12, 2023
Hope this helps.
Thank you fot your reply.
I'm not very familiar with lists. I know the values are like stored and can be called with {} but I don't really know how to retrieve them.
I had already tried the NeighborFinder (Candidates Only mode somhow only returns unmatched elements) but it's not very clear to me what happens
4ntoine
  • December 12, 2023
Hope this helps.
It now seems to work, thank you. I had an error in my formula @sqrt($(Resolution)^2 + $(Resolution)^2) * 1.1, as FME Arimthmetic Editor doesn't understand ^ as power, I have to write @sqrt(@pow($(Resolution),2) + @pow($(Resolution),2)) * 1.1 and everything works fine
joepk
  • December 12, 2023
Glad to see the NeighborFinder approach works for you. Below is some more explanation about the lists.
This is my dummy workspace:
imageThese are the settings of my NeighborFinder:
imageAs you can see under Attribute Accumulation, I collect all values from the Z attribute to the list called _NeighborList.
You can explode the list with the ListExploder, which results in this:imageimageThe ListExploder basically multiplies your input features with the amount of list elements. I have prefixed the neighbor attributes with nb_ to avoid confusion. 'Z' and 'ID' are from the original point and 'nb_Z' and 'nb_ID' are from the neighboring points.
As you can see, ID 1 has three neighbors, so three points are generated. These points have the attributes of ID 1 (Z = 3.9) and of the neighbor points ID 2, ID 11, ID 12 (nb_Z = 2.6, nb_Z = 3.2 and nb_Z = 1.3).
You can do further calculations with these exploded features and e.g. merge it back together based on the original ID.
Have fun!
4ntoine
  • December 13, 2023
Worked perfectly for me, thanks!
