I have the problem that my zip file gets overwritten when a new file is should be added to the zip file, resulting in that all existing files in the zip file are lost. I'm using a fanout for the file to be written into a specific zip file.
  • September 1, 2020
  • 40 views
jan
The FME version is 2019.2
Forum|alt.badge.img+50
That's default behaviour and I don't think it can be changed. Best thing to do is write to a temporary location and then use a SystemCaller to call a zip command line. I know 7Zip is capable of adding to existing zip files.
Annotation 2020-09-01 091153
Here's one I used a while ago to bulk-add a lot of files to a lot of existing zipfiles.
nielsgerrits
Forum|alt.badge.img+54
As an alternative, you can use the ZipArchiver transformer from the hub.
ZipArchiverParameters
This is what I use, and prefer over the SystemCaller.
jan
  • September 1, 2020
Hmm, that's funny, because a zip file has been treated as a folder previously in FME (I think)! Thank you for the reply!
