I have photos stored in a database. Normally, I simply use an AttributeFileWriter to extract the photo. However, I want to use the JPEG Writer. Can JPEG Writer be used from an Attribute?
  • Apr 15, 2022 6:44 PM UTC
  • 269 views
bellrosemike
I wish to use the JPEG writer rather than the attribute file writer, because I want to add EXIF data to the image that doesn't exist in the original BLOB. I do not see a way to add this EXIF information when simply using an attribute File Writer.
Best answer by chrisatsafe
Hi @bellrosemike​ ,
Instead of using the AttributeFileWriter, try the RasterReplacer and connect it to a JPEG writer. The RasterReplacer decodes a binary attribute containing encoded rasters stored as Blobs, replacing the feature’s geometry with the decoded raster.
chrisatsafe
  • Apr 18, 2022 8:54 PM UTC
Hi @bellrosemike​ ,
bellrosemike
  • Apr 26, 2022 8:48 PM UTC
Thank you Chris, that method worked perfectly. I didn't even know that the RasterReplacer transformer existed, but it did exactly what I needed.
crutledge
Forum|alt.badge.img+55
  • Apr 6, 2025 1:28 PM UTC
Hi @bellrosemike​ ,
Great tip. Still Valid. Great way to deal with the _response_body of an HTTPCaller when the API returns an imageblob.
danilo_fme
Forum|alt.badge.img+58
  • Apr 6, 2025 3:41 PM UTC
Hi @bellrosemike​ ,
Great solution ​@chrisatsafe
