I want to connect the pipelines to each other in Z coordinates at the place where there is a mutual vertex intersection.
I have multiple water pipeline networks (polyline Z) which are all located on their own standard depth, e.g. house connections -0,80 distribution -1,00 transport pipes -1,20. How can I connect the last vertex of each network in Z where they intersect
Best answer by ctredinnick
The key is you can use a VertexCreator to insert a point at a specific index in your line, and this can connect the line endpoint to another location, including in the Z dimension.
You first create nodes along the line you want to connect To, and join their x,y,z coordinates as attributes to the line which you want to connect to each node
Will be something like this: This is only connecting one line type to another, you'll need to control whether you add the vertex to the line startpoint or endpoint if the line directions are not consistent.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
