I have multiple lines and corresponding two point for each line. I want to trim those lines by keeping segment between two points. I have tried pointOverLine which does segment the line but I am having difficulty eliminating remnant.
  • Sep 10, 2021 3:52 PM UTC
  • 33 views
@pangenib​ Try an combination of LengthToPointCalculator and Snipper. LengthToPointCalculator will give the length from the start of the line to the point, Snipper will shorten the line by that length. You might have to use Orientor to reverse the line for the second point.
  • Sep 10, 2021 5:26 PM UTC
Thanks @Mark Stoakes​ for your quick response. Suggested approach was perfect. Solved!
