I have a workspace that reads a .csv file. I recently ran across a problem where the reader output had no outputs on some User attributes. I found that I had the wrong case on the headers of the csv file.
  • December 23, 2022
  • 18 views
Is there a way to:
  1. make a reader case-insensitive?
  2. Change the case of the headers?
  3. Stop the workspace and generate an error if the wrong case is encountered in the file headers?
Best answer by markatsafe
@dutchtower​ There's a webinar on schema drift that might give you some ideas - including using the SchemaScanner or FeatureReader to get the schema and compare it to an old one.
But... when you add a CSV reader to your workspace, under the reader parameters, Advanced, Field Names, try setting Case Sensitive Field Names: No
Forum|alt.badge.img+49
Regarding #3: you could use a Schema reader to read the csv schema and then compare it to what it should be. If it matches, you can use a FeatureReader to read the actual data.
It may also be worth exploring the workflow before the data gets to FME, if there's case differences being introduced there that's obviously not a good thing in terms of consistency.
  • December 29, 2022
  • December 29, 2022
I added a new CSV reader and set the Case Sensitive Field Names to No and replaced the original CSV Reader and SHAZAAM! it worked. I'll take a look at the webinar Mark mentioned and see about adding a Schema drift alert. Thanks, everyone!
