I have a set of records which have a a couple of attributes, among them one attribute identifying to which group they belong to (a,b or c).
  • Dec 10, 2021 8:35 PM UTC
  • 6 replies
  • 72 views
katt
Forum|alt.badge.img+12
I want to make sure that I have the same number of records in each group. What transformer to use?
btw I want to preserve each record's attributes values as I want to write the records to a db later on.
drc43
Forum|alt.badge.img+13
  • Dec 10, 2021 10:21 PM UTC
Hi @katt​ ,
It sounds like you need the StatisticsCalculator. If you set the Group By, to the group attribute in your dataset, and select the Total Count statistic, it will output both a Summary with a count of the number of records belonging to each group, and also output all the records with the count added as an attribute. Because you are only calculating a total count of records, you can use any Attribute, but I usually use the primary key when I do it. Hope that helps.
hkingsbury
Forum|alt.badge.img+73
  • Dec 12, 2021 9:39 PM UTC
Hi @katt​ ,
I question i'd have, is do you require one feature with all counts? eg
a    b    c
21   21   21
or a feature for each count eg
grp  cnt
a    21
b    21
c    21
or are you wanting the count as a separate attribute against each feature?
katt
  • Dec 13, 2021 1:55 PM UTC
a    b    c
21   21   21
grp  cnt
a    21
b    21
c    21
Yes, for example: group a =3 records; group b =17 and group c=34 records. Once I calculated the number of records per group, I want to compare them with each other. Are as many in group a as in group b and as in group c ? I want to detect if there are not the same number of records in each group. I don't mind the way it's done.
hkingsbury
  • Dec 13, 2021 8:03 PM UTC
a    b    c
21   21   21
grp  cnt
a    21
b    21
c    21
Have a look at the attached - this way is really only suitable if you're comparing a handful of groups as it requires manual attribute exposing
katt
  • Dec 13, 2021 8:47 PM UTC
a    b    c
21   21   21
grp  cnt
a    21
b    21
c    21
Thank you. Would you be able to provide me a FME 2018 compatible script?
hkingsbury
  • Dec 14, 2021 3:18 AM UTC
a    b    c
21   21   21
grp  cnt
a    21
b    21
c    21
see attached, the earliest version i have is 2018.1
