I have a geodatabase that I want to upload to arcgisonline. I set the projection to be 28992 but when I check the projection in AGOL, it will always be Spatial Reference: 102100 (3857). I would like it to be 28992. Is there any way to do this from FM
  • Oct 12, 2022 1:37 PM UTC
  • 146 views
  • I have multiple layers in my GDB
  • I know I can get the correct projection using share from arcgis pro, but I don't have an arcgis pro subscription for this account, only arcgisonline
  • I will need to keep updating the layers keeping the projection in arcgisonline 28992
  • thank you in advance for your help
Best answer by markatsafe
@ionveronica87​ if you set the Target WKID or Coordinate System, then FME should create the Feature Class with the desired spatial reference.
Forum|alt.badge.img+63
If I'm not mistaken ArcGIS Online uses EPSG:3857 (Web Mercator) by default to store the data and this can't be overridden.
I knew the same until I found out and tested that it can be other than the default projection when using ArcGis Pro to upload. I thought maybe there is a way from FME as well, or maybe anyone else tried to do this and found a solution. Thank you for your reply @Hans van der Maarel​
  • Oct 12, 2022 7:40 PM UTC
Thank you @Mark Stoakes​  for your help, it worked perfectly!
