I have a file with points and as an attribute I have the measurement with respect to the LRS. How to view the points on the map?
  • Jul 31, 2023 1:39 PM UTC
  • 84 views
maica
Forum|alt.badge.img+4
daveatsafe
Forum|alt.badge.img+24
  • Jul 31, 2023 5:10 PM UTC
Hi @maica​,
The following FME webinar covers this topic:
https://www.safe.com/webinars/linear-referencing-lrs-how-fme-measures-up/
The process is to merge the line geometry on each point with a FeatureMerger, then snip it to a point using the Snipper transformer, based on the measurement value.
maica
  • Aug 1, 2023 9:53 AM UTC
Hi @maica​,
Thanks a lot...
but in a Snipper transformer, in the starting Location and Ending Location, must I insert the same measure?
daveatsafe
  • Aug 1, 2023 6:30 PM UTC
Thanks a lot...
Yes, if you use the same measure for both the Starting Location and Ending Location, the Snipper will produce a point at that location, instead of a line.
maica
  • Aug 2, 2023 9:05 AM UTC
Thanks a lot...
Ok, it's work perfectly! :-)
If, instead, I have a network and linear events and I want find measure (from and to) for each event with respect to the network, what is the better solution?
I try to use the LineonLine Overlayer transformer, but the result is not what I expected.
Maybe are the self-intersections the problem?
If I find start and end vertexs and, then, I use NieghborFinder transformer, it seems to work fine. But I don't know if it is the better solution...
