I have a csv file containing lat/long feature data. I want to convert this in to BNG easting/northing ESRI shapefiles.
  • February 13, 2018
  • 40 views
How can I convert a csv file in lat/long data into an Esri Shapefile that is BNG easting/northing?
debbiatsafe
Forum|alt.badge.img+20
  • February 14, 2018
Hi @jamesward
I would recommend taking a look at the following article for instructions on how to convert from CSV to spatial geometry. This article demonstrates how to create Shapefile points from tabular CSV data (with video):
https://knowledge.safe.com/content/kbentry/1493/index.html
The following article covers creating points, lines, or polygons from CSV:
https://knowledge.safe.com/articles/56486/converting-from-csv-data-2.html
To convert your data to British National Grid, you would need to define your source coordinate system and use one of the Reprojector transformers within your workflow to reproject the data. For this part, I would recommend this article:
https://knowledge.safe.com/articles/585/using-coordinate-systems-within-fme.html
Hope this helps,
Debbi
  • February 14, 2018
Many thanks @DebbiAtSafe
