I have a collection of Roads (lines) and would like to find the nearest other road(line) to the starting point..
  • May 19, 2021
  • 37 views
preiser
Forum|alt.badge.img+4
I have used snipper to get the starting points of the lines, then I used NeighbourFinder to find the nearest line to the starting point, but i want to exclude lines with same id as my point..
It is possible with Postgis, but know that I got a license I prefer FME if possible.
Best answer by nielsgerrits
I think you need to choose you want to find 2 matches, use a list, explode the list, discard the match with the same ID and keep the other one.
nielsgerrits
Forum|alt.badge.img+64
  • May 19, 2021
preiser
  • May 19, 2021
Ok I will go with that solution, and save it in my Toolbox.. Thanks a lot
