I have 2 lines in 1st line there will be different height with every node and i want to move 2nd line with reference 1st line and 2nd line height to be varied for nearby nodes with reference line
  • Oct 24, 2019 9:05 PM UTC
  • 79 views
I have 2 lines in 1st line there will be different height with every node and i want to move 2nd line with reference 1st line and 2nd line height to be varied for nearby nodes with reference line but when i use offsetter only one common z values are to be assigned to move the line with nearby reference line with no variation in z values so i want height variation in linear line with nearby reference line z values@ PranneshGeo
srg
Forum|alt.badge.img+10
  • Oct 25, 2019 10:20 AM UTC
@pranneshgeo, do the nodes have height values tagged to them? the Z offset need not be a constant value. It can be an attribute as well or even an expression
HTH
Happy FME-ing :-)
SRG
gio
Forum|alt.badge.img+15
  • Oct 25, 2019 2:28 PM UTC
You need to do the height reference to the vertices. (if I understand the question right)
Either extract the vertices, find nearby reference, affine/adapt z value and rebuild line.
Or do it to its coordinates without rebuilding (manipulate geometry string), more difficult though.
