I am using the ESRI Reprojector to reproject my data for online use in ArcGIS Online but encounter an error
  • June 20, 2022
  • 107 views
scottshenberger
I have a workbench that has a ESRI Reprojector that reprojects from HARN to Web Mercator before publishing to out to a service in ArcGIS Online.image.pngEach time get the error:
Reprojector: Invalid reprojection parameters
%0 Writer: Failed to reproject feature with coordinate system '%1' to '%2'. Verify that the coordinates and coordinate systems are valid, and try again
ARCGISONLINEFEATURES writer: A fatal error has occurred. Check the logfile above for details
CnxParcel_Overlay (SpatialRelationshipFactory): A fatal error has occurred. Check the logfile above for details
Scott
daveatsafe
Forum|alt.badge.img+19
  • June 23, 2022
Hi @scottshenberger​,
My first thought is that the source data may not match the State Plane coordinate system chosen. Please view the source in the Data Inspector with Background Map turned on and check that the data is where it should be, and that it's coordinate system is HARN/AZ.AZ-CIF or _HARN/AZ.AZ-CIF_0.
