I am trying to transform a list of data from a sql table to table like format - probably not making sense so I'll try an explain more
  • Jan 20, 2021 5:18 AM UTC
  • 37 views
The following is how the data comes in using SQLCreator
beforeAnd this is how i want it to look
afterThe other tricky part is that there is no limit on the number of nar_num records (rec_seq) that can be linked to a single ass_num - at the moment I have a max of 17 but that could go up or down
I looked at the pivoter and didnt have any luck with that but i am new so maybe i am missing something.
Anyone have any ideas?
@left65​ A combination of Aggregator followed by the HUB Custom transformer ListBreaker should do it.
  • Aggregator - use Group By : ass_num and create a list from attribute 'nar_num'. Use Mode: Attributes Only (or you could try ListBuilder)
  • ListBreaker - break up the list of 'nar_num'
  • Jan 29, 2021 1:02 AM UTC
Thanks Markatsafe
