I am trying to extract just the email address from a string of text, for example: Joe Blogs | Senior Advisor | Joe.bloggs@example.co.uk | pointOfContact
  • Sep 20, 2021 4:56 PM UTC
  • 5 replies
  • 116 views
I have tried the StringReplacer but I'm struggling to remove everything I need to, without also removing part or all of the email as well. Any help would be appreciated, thank you.
warrendev
Forum|alt.badge.img+28
  • Sep 20, 2021 5:34 PM UTC
Hi @clare42​ ,
Try this regex with the StringSearcher transformer.
[\w.+]+@[\w+\.\w.]+
The output should be: Joe.bloggs@example.co.uk
  • Sep 21, 2021 2:28 PM UTC
Hi @clare42​ ,
[\w.+]+@[\w+\.\w.]+
Hi, thank you. It works much better, but it seems to cut the end bit off, so I end up with Joe.Bloggs@example
danilo_fme
Forum|alt.badge.img+58
  • Sep 21, 2021 3:03 PM UTC
Hi @clare42​ ,
[\w.+]+@[\w+\.\w.]+
Nice!
warrendev
  • Sep 21, 2021 3:07 PM UTC
Hi @clare42​ . My regular expression knowledge isn't the best, so you might want to use this regular expression that should be a safer bet in capturing email addresses.
Source: https://emailregex.com/
Regex:
(?:[a-z0-9!#$%&'*+/=?^_`{|}~-]+(?:\.[a-z0-9!#$%&'*+/=?^_`{|}~-]+)*|"(?:[\x01-\x08\x0b\x0c\x0e-\x1f\x21\x23-\x5b\x5d-\x7f]|\\[\x01-\x09\x0b\x0c\x0e-\x7f])*")@(?:(?:[a-z0-9](?:[a-z0-9-]*[a-z0-9])?\.)+[a-z0-9](?:[a-z0-9-]*[a-z0-9])?|\[(?:(?:25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)\.){3}(?:25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?|[a-z0-9-]*[a-z0-9]:(?:[\x01-\x08\x0b\x0c\x0e-\x1f\x21-\x5a\x53-\x7f]|\\[\x01-\x09\x0b\x0c\x0e-\x7f])+)\])
In my testing it does in fact capture the email address you provided in your example.
parametersfme
  • Sep 23, 2021 9:32 AM UTC
Thank you 😊
