I am trying to expose IFC attributes based on the ifc_property_set collection of names. The end result should be a feature with only the ifc_property_set attributes exposed on the feature.
  • Nov 13, 2020 4:28 AM UTC
  • 0 replies
  • 39 views
stuartpaice
Participant
As the IFC property sets are configured in other systems i do not have prior knowledge of the attributes to expose these for the writers. I need to be able to feature attribute cleanup so that i can expose these attribute collections without prior knowledge of the feature information.
I have successfully exposed the attributes from the collections as a feature attribute but these are still hidden from the writer. I am able to interrogate each feature and build a picture of those attributes in Python but cannot seem to expose these programmatically.
def processFeature(feature):
    print("**Processing feature**")
    print(feature.getAttribute('ifc_property_set'))
    #ifcpropertieslist = feature.getAttribute('ifc_properties')
    print(feature.getAllAttributeNames())
    i=0
    attrNames=feature.getAllAttributeNames()
    elementCount = int(feature.getAttribute("_element_count"))
    print(elementCount)
    exposeAttrsNames={}
    for i in range(elementCount):
        attrname = "ifc_properties{"+str(i)+"}.name"
        #print(attrname)
        #print(feature.getAttribute(attrname))
        featAttrName = feature.getAttribute(attrname)
        exposeAttrsNames[featAttrName] = feature.getAttribute(featAttrName)
    print(exposeAttrsNames)
    pass
Excuse the disorganization its a work in progress
FMEIFCAttr
 Any ideas would be apricated.
