I am needing to create a polyline from an excel spreadsheet that does not contain any Coordinate Information but has measures.
  • May 22, 2023 4:39 PM UTC
  • 64 views
The output needs to be a horizontally flat line that is built on the values from the measure field. I would also like to insert a vertex at every measure change.
DanAtSafe
Forum|alt.badge.img+23
  • May 23, 2023 6:40 PM UTC
Hi @jberneathy​ Use a VertexCreator to replace the geometry with a point where X is the measure field and Y is the constant value of your horizontal line. Then join the points together with a LineBuilder.
