HttpCaller Json - how to process each page individually in FME?
  • Jun 28, 2019 9:54 AM UTC
  • 5 replies
  • 138 views
I’m using HttpCaller for a REST JSON get call.
On the response I use JSONFlattener & JSON Fragmenter with query json["{data}"] giving the following 2 pages-
(personal data redacted for this post)
data{0}.applicationId (encoded: utf-8)
data{0}.applicationStatus (encoded: utf-8)
data{0}.applicationTypeCode (encoded: utf-8)
data{0}.dob (encoded: utf-8)
data{0}.eligibilityCode (encoded: utf-8)
data{0}.name (encoded: utf-8)
data{0}.nino (encoded: utf-8)
data{0}.partyTypeCode (encoded: utf-8)
data{0}.submissionDate (encoded: utf-8)
data{1}.applicationId (encoded: utf-8)
data{1}.applicationStatus (encoded: utf-8)
data{1}.applicationTypeCode (encoded: utf-8)
data{1}.dob (encoded: utf-8)
data{1}.eligibilityCode (encoded: utf-8)
data{1}.name (encoded: utf-8)
data{1}.nino (encoded: utf-16)
data{1}.partyTypeCode (encoded: utf-8)
data{1}.submissionDate (encoded: utf-8)
(Pagination set to max 50 pages)
How can I process each page individually as I’ll be using the attributes from each page to then populate a XMLTemplater to POST a SOAP request?
Thanks!
If I've understood, could you not use a ListExploder on data{} to produce a single feature for each page outputted and then an AttributeExposer?
  • Jun 28, 2019 10:05 AM UTC
Cheers David - I'll give that a go...Thanks
  • Jun 28, 2019 10:20 AM UTC
Hi David,
The "response_body" is not available for the ListExpoder to pass the json response to -
Hi David,
Try exposing the attribute data{} in the JSON fragmenter or flattener
  • Jun 28, 2019 11:27 AM UTC
Hi David - You're a star!
Working like a dream....
Cheers
