HTML2PDFConvertor
  • Jun 3, 2025 2:40 PM UTC
  • 139 views
kristinsbrev
We use the transformer HTML2PDFConvertor, but for some reason it has stoped working and reject the input. Anyone who has an idea?
j.botterill
Forum|alt.badge.img+69
  • Jun 4, 2025 6:09 AM UTC
this is a custom transformer https://hub.safe.com/publishers/safe-lab/transformers/html2pdfconvertor and reading over the usage and Output Ports section, you’ll find:
  • Page size, which either can be chosen from the standard list (Letter, Legal, A4 etc) or specified in points as two space-separated integer numbers (width and height);
 https://wkhtmltopdf.org/
raghavendrans
Forum|alt.badge.img+28
​@kristinsbrev
The rejection code or message should give you the hint on where the issue is?
SRG
j.botterill
  • Jun 5, 2025 2:57 AM UTC
I can also see you have a ‘list’ as the PDF output name. You might need a ListExploder prior to this HTML2PDFConvertor
kristinsbrev
  • Jun 5, 2025 6:04 AM UTC
​@j.botterill and ​@raghavendrans - Thank you for your respond. We solved the problem and it is now running again. the problem was the connection to the .exe-file using FME flow.
