How use group by on custom transformer?
  • Aug 24, 2020 9:37 AM UTC
  • 633 views
How add a group by option in my custom transformer? Example:FME_group_by_3
Another example might be if I put a Counter with local scope starting at 0 inside the custom transformer, then I would like to group by for instance _creation_instance - to get three features out all with _count = 0.
In the Custom transformer I see a setting Group by <not set> but I am not able to edit that one (there are no suggestions when opening it). I tried creating a parameter called fme_group_by but that did not work either. How can I do this?
Best answer by ebygomm
Right click on the Group By: Parameter to create a parameter (this is named FME_PROCESS_GROUP_BY by default), then in your main workspace, in your custom transformer you should have an option to set the Group By parameter, e.g.
Capture
Forum|alt.badge.img+54
  • Aug 24, 2020 10:01 AM UTC
Capture
  • Aug 24, 2020 10:28 AM UTC
Capture
Perfect! Thanks @ebygomm​ !
