How to xolor the firdt column in PDF ?
  • Oct 10, 2025 8:51 PM UTC
  • 114 views
gogopotter90
Forum|alt.badge.img+14
Hallo ,
How to Color the first column  at table in PDF ?
I used the PDFPageFormatter but  I faced a problem that i want to color the first column at table in  PDF output, which contains the attribute names,that i have created a table by pdf page formatter
Could someone advise me on how to color the first column?
FME 2021
Best answer by crystalatsafe
Hi ​@gogopotter90
This process is somewhat complicated, but one approach is to find the lowest X value of a table to determine which cells are in the first column, and then apply colouring to those cells.
I have attached a sample workspace that does this.
I hope this helps!
crystalatsafe
Forum|alt.badge.img+32
  • Oct 16, 2025 8:17 PM UTC
Hi ​@gogopotter90
I hope this helps!
