How to write XML metadata to Esri Geodatabase (ArcSDE Geodb Raster Dataset)?
  • Sep 13, 2017 8:19 AM UTC
  • 10 replies
  • 233 views
thomas_merkus
For a project I’m trying to use FME to directly write XML formatted metadata, stored in an attribute, to an ArcSDE Oracle database with FME.
Following these examples (1&2), It works fine with a SDE Feature Class & the Esri Geodatabase (ArcSDE Geodb) writer.
However, for a SDE Raster Dataset I’m experiencing some difficulties:
  • The Esri Geodatabase (ArcSDE Geodb) writer won’t let me write to SDE Raster Dataset
  • The Esri Geodatabase (ArcSDE Geodb Raster Dataset) writer doesn’t have the option to set the allowed geometries to geodb_metadata.
Does anybody have experience with this issue (and perhaps a solution), or am I doing something wrong?
fmelizard
Forum|alt.badge.img+22
  • Sep 13, 2017 3:08 PM UTC
Hi @thomas_merkus, using the Raster format, if you were to create the geodb_type attribute and set it to "geodb_metadata" (as in Writing XML Metadata to Geodatabase), are you able to write successfully?
helmoet
Forum|alt.badge.img+8
  • Sep 13, 2017 3:16 PM UTC
Hi @thomas_merkus What error do you get? And does this help? My guess is that you should use the FME parameter geodb_type to set to geodb_metadata, not the geometry type.
thomas_merkus
  • Sep 14, 2017 10:04 AM UTC
Thx @helmoet & @TiaAtSafe! Yes that is the same method I tried. I noticed that in some cases it actually works and in others I got an error message. Moreover, I was wondering if this is the correct way to do it. The errors are then probably due to some other issue.
fmelizard
  • Sep 14, 2017 3:27 PM UTC
What was the error message(s) you were getting?
thomas_merkus
  • Sep 19, 2017 12:45 PM UTC
@helmoet @TiaAtSafe The workspace error is:
|ERROR |Error occurred using IXmlPropertySet2::setXml(). HRESULT = -2147215103. File: geodbutilities.cpp Line #: 2881
It only happens for certain raster datasets, while others work fine.
tnarladni
Forum|alt.badge.img+24
  • Oct 11, 2017 1:46 PM UTC
@Thomas_merkus, were you able to debug your problem? I have a similar error for a vector featureclass and only on this featureclass in two different SDE databases.
thomas_merkus
  • Oct 11, 2017 2:28 PM UTC
@tnarladni, Not yet unfortunately. Although, I have not tried writing directly into Oracle instead of SDE, but that might be more of a workaround.
helmoet
  • Oct 14, 2017 3:18 PM UTC
Hi @thomas_merkus, here is where I quit. Might be an idea to submit a support call at Safe's?
fmelizard
  • Oct 16, 2017 2:25 PM UTC
@thomas_merkus please do submit a case if this is still causing your grief. You can submit a case along with the workspace and log file here .
thomas_merkus
  • Oct 17, 2017 1:16 PM UTC
@helmoet @TiaAtSafe I have submitted the case. I'll keep you updated!
