How to write to a dxf file with attributes?
fme_hans
Forum|alt.badge.img+5
I want to write geometry and attribute data to a dxf file. How do I make sure that the attribute data is saved in the dxf file? All I get now is the geometry in the dxf.
saraatsafe
Forum|alt.badge.img+8
  • June 26, 2023
Hi @fme_hans​, if you're using the Autodesk AutoCAD DWG/DXF writer, the default Attribute Setting will not include your attributes. You can change this by going into your writer's Parameters and selecting either Extended Entity Data or Inserts. The writer documentation goes into more detail. I hope this helps and please let me know if you have any questions!
fme_hans
  • July 6, 2023
"Extended Entity Data or Inserts" did it. I had missed them.
Thanks.
