How to write text and add values from different attribute in one cell
  • January 6, 2023
  • 692 views
gogopotter90
Forum|alt.badge.img+13
Hello ,
i would like to combine different values from different attributes then add them in one cell and write string text +value of specific attribute 1
then add new line and write string text + value of other specific attribute .
How could I achieve it ?
thanks in advance
FME 2021
Best answer by dustin
Probably the most straight forward way will be in an AttributeManager. In this example, the values from Att1 and Att2 were combined in a new attribute (Att3), where the Text Editor was used to concatenate different attribute values and add static text. You can also add new lines in the Text Editor.imageimage
dustin
Forum|alt.badge.img+31
  • January 6, 2023
