How to write summary statistics to a file or pdf
  • Nov 9, 2022 10:51 PM UTC
  • 102 views
I have a pretty complicated model which has many input data sets, transformers and lots of intermediatary data. I need to write a summary of the statistics at the end of the procedure including total area of results, proportions and ratios taken from the data. Which Transformers could I use to select or create statistical summaries and write them to text?
mirco
  • Nov 10, 2022 7:27 AM UTC
I would try the StatisticsCalculator.
dustin
Forum|alt.badge.img+36
  • Nov 10, 2022 11:53 AM UTC
As mentioned, StatisticsCalculator to compile the data, followed by a Text File writer. text_line_data is the attribute you will need to write your statistics into. Each feature input to the writer will be a new line in the text file.
