How to write extended data in KML output as kml_data instead of kml_schema_data.
  • Jul 26, 2023 12:58 PM UTC
  • 103 views
wasim13
Participant
Forum|alt.badge.img+3
KML output written in kml_schema_data,I am not able to write in kml_data as shown in expected ouput image
Expected Output
debbiatsafe
Forum|alt.badge.img+24
Hello @wasim13​
You should use the kml_data{}.name and kml_data{}.value list structure to write extended data with the KML writer (documented here). You should be able to use an AttributeExploder (explode as list) to create this list structure. You will have to use the Ignore Attributes Containing parameter to exclude any attributes you do not want written as extended data.
I have attached an example demonstrating this workflow and I hope it helps!
