how to write a formel
  • Jul 8, 2019 9:32 AM UTC
  • 42 views
terezia86
hi,
how can I write in AttributeCreator iff the Value is missing than set Value to 0 ?
I have the created a form, see screenshot, and that is correct, but sometimes the Value of "_Anzahl_DT" is "missing" and then I do not get any Value in results..
I need to write in this form this case, that when Value of _Anzahl_DT is missing, than write 0 instead so the formel can count it with 0.
thanks.
nielsgerrits
Forum|alt.badge.img+67
You can put a conditional statement in the result.
conditional2018.fmwt
  • Jul 8, 2019 10:40 AM UTC
Another tip is to clean up the data with a NullAttributeMapper before the AttributeCreator. Then you can map <missing> to 0.
