How to use use adjacent (previous) feature handling in AttributeManager to calculate value for same attribute
  • Mar 27, 2023 9:58 PM UTC
  • 209 views
johnk
I have a workflow where I need to forecast particular values. The formula to calculate this forecast value (in Attribute A) needs to reference the previous feature in Attribute A, but the AttributeManager doesn't allow you to reference ajacent features (in this case, previous) for the same attribute. Is there a way I can do this? I wonder if a looping process would help.
Thanks
Best answer by johnk
Ah - I was trying to do the calculation on an atttribute which id created in the same attributemanager. I've added the attribute before using attributecreator and now works
@John Kreft​ Can you give us a little workspace example of what you're trying to accomplish? AttributeManager and AttributeCreator should be able to return the value of an attribute from the previous feature:
@Evaluate(@Value(_count)+@Value(feature[-1]._count))
johnk
  • Mar 28, 2023 1:19 AM UTC
