how to use regex to capture string and create attribute
  • Mar 10, 2020 2:18 PM UTC
  • 159 views
I am trying to find a string with regex and put it in an attribute. I have used the stringReplacer, but this means I would have to search for what I don't want to capture and replace it with nothing so that what is left is the string I want to capture.
It seems as though capture-groups do not capture strings for subsequent use in fme.
Forum|alt.badge.img+54
  • Mar 10, 2020 2:29 PM UTC
Try the string searcher instead
  • Mar 10, 2020 2:31 PM UTC
Also, you need to specify a list name for the regex capture groups, otherwise you won't find them in the output:
