how to use current calculated feature in the next step.
  • Jan 13, 2023 11:24 AM UTC
  • 7 replies
  • 100 views
aska
I have this equation in Excel:
=A2-($A$2-$G$2)*B4/SUM($B$4:$F$4)
this A2 and B4 has to change every row. so that the value I just got from the current row calculation needs to be used in the next step.
9.83,8.82,7.56,6.41,5.41,5
minus
0,1.01,1.26,1.14,0.99,0.4
it starts with 9.83-0, then 9.83-1.01, then the result which is 8.81-1.26 and so on.
how can I write this equation? or how can I get the result of previous row calculation in the current row?
Best answer by nielsgerrits
AttributeCreator has the same functionalities like AttributeManager. I have tried to use CurrentAttribute function, however, it returns 0. May you please show me how the arithmatic equation whould look like? or is there a way to get the value of CurrentAttribute(feature[-1])?
Here you go.
nielsgerrits
Forum|alt.badge.img+67
You can do this using an AttributeCreator, make sure to enable adjacent feature handling.
aska
  • Jan 13, 2023 12:59 PM UTC
nielsgerrits
If you add some example data it is easier to explain, so much possibilities.
aska
  • Jan 13, 2023 2:09 PM UTC
the data is column1 + value 9.83
ideal output is column2
column1 Column2
0 -> 9.83-0 ~ 9.83
,1.01-> 9.83-1.01 ~ 8.82
,1.26 -> 8.82-1.26 ~ 7.56
,1.14 -> 7.56-1.14 ~ 6.41
,0.99 -> 6.41-0.99 ~ 5.41
,0.4 -> 5.41-0.4 ~ 5.00
nielsgerrits
  • Jan 13, 2023 2:13 PM UTC
Here you go.
aska
  • Jan 13, 2023 2:43 PM UTC
thank you @nielsgerrits​
I imagine to use the feature-1 of an attribute, you must have defined the attribute a step ahead. good learning. thank you
nielsgerrits
Cheers :)
