How to use a parameter to determine which workspace runner to execute.
  • Sep 2, 2021 1:17 PM UTC
  • 74 views
plynn
Forum|alt.badge.img+10
I have created a User Parameter of type Choice. I am trying to transfer control to a workspace runner based on what is selected. So far, I am having no success. When I run the workspace, the value is showing as 0 instead of my actual choice.
hkingsbury
Forum|alt.badge.img+73
  • Sep 2, 2021 11:26 PM UTC
The test filter is using the attribute set in the creator. You have setup a parameter to hold the value but havent assinged that to an attribute.
You can use the parameter value directly in the testfilter, or use a parameter fetcher after your create to place the parameter on an attribute
