How to update XML attribute with content of list attribute
  • Jul 19, 2018 2:33 PM UTC
  • 143 views
My features have an attribute containing an XML document and a list attribute. As an example, imagine the XML attribute containing this document:
<?xml version="1.0" encoding="UTF-8"?>
<root>
  <foo bar="aaa"/>
  <baz>
    <foo bar="bbb"/>
    <foo bar="ccc"/>
  </baz>
</root>
And the list attributes containing these values:
list{0}.ident = "aaa"
list{0}.value = "xxx"
list{1}.ident = "bbb"
list{1}.value = "yyy"
list{2}.ident = "ccc"
list{2}.value = "zzz"
What I want to achieve is to update the XML attribute so that it contains this modified XML document:
<root>
  <foo bar="xxx"/>
  <baz>
    <foo bar="yyy"/>
    <foo bar="zzz"/>
  </baz>
</root>
I think this should be easily doable using the XMLXQueryUpdater in conjunction with the FME XQuery functions, but I just don't get it right...
Thanks for your help,
David
Best answer by takashi
Hi @dfundter, it would be a little advanced XQuery expression.
let $m := <map>{
    let $values := fme:get-list-attribute("list{}.value")
    for $key at $i in fme:get-list-attribute("list{}.ident")
    return <item key="{$key}" value="{$values[$i]}"/>
}</map>
for $foo in //foo
return replace value of node $foo/@bar with $m/item[@key = $foo/@bar]/@value
  • Jul 19, 2018 3:18 PM UTC
let $m := <map>{
}</map>
for $foo in //foo
  • Jul 20, 2018 6:28 AM UTC
let $m := <map>{
}</map>
for $foo in //foo
Thanks @takashi! The intermediate XML node didn't come to my mind. I was stuck trying to inline loop through the list...
  • Jul 20, 2018 6:30 AM UTC
let $m := <map>{
}</map>
for $foo in //foo
Another solution. This may be simpler.
let $idents := fme:get-list-attribute('list{}.ident')
let $values := fme:get-list-attribute('list{}.value')
for $foo in //foo
return replace value of node $foo/@bar with $values[index-of($idents, $foo/@bar)]
  • Jul 20, 2018 7:12 AM UTC
for $foo in //foo
Very nice!
