How to update the 'classification' attribute in a point cloud in FME Workbench?
  • Oct 16, 2017 9:15 PM UTC
  • 144 views
Currently, my point cloud file has the classification attribute to 0 which I want to update it to 1
ulfme
Forum|alt.badge.img+14
  • Oct 17, 2017 11:33 AM UTC
Hi!
One fairly simple approach is to first split out the PC depending on Classification and then use the PointCloudExpressionEvaluator to update the classification. After this you glue it together with the PointCloudCombiner.
(It might also be possible even to have a condition in the PointCloudExpressionEvaluator to save some speed and Transformers - but this is a fairly simple alternative).
I include a screenshot:
Note - if you are running this on several input-files you should use a Group By statement in the PointCloudCombiner (for instance on fme_basename) so you don't end up with one large file.
  • Oct 18, 2017 7:20 PM UTC
Thank you very much @ulfme. I really appreciate the time you took to make the workflow to explain.
Since my point cloud is unclassified, I cannot use the initial approach you mentioned. I am clipping the point cloud and assigning new classification values to the clipped feature. So I did try the expression evaluator to update the classification field.
Thanks again :D
