How to update multiple attributes in an element in the XMLUpdater from an FME list?
  • Jan 17, 2020 3:30 PM UTC
  • 9 replies
  • 321 views
stephstedman
Forum|alt.badge.img+7
Hi everyone.
I am new to XML and am having some difficulties using the XMLUpdater and XQuery. My issue is around updating 3 attributes within an xml element from 3 attributes in an FME list to create multiple children. When I do this for a record which has say 2 items in the list it’s producing 9 children instead of 2, do I need to group my data somewhere in my XQuery?
I’ve attached a sample workbench and data.
I am reading an Excel document, then creating a list of all LCS_Codes and their measures per TAC_Code. I then want this list to form the children of a location element within my XML. So I’d hope to go from something like this:
Input table:
To this output XML text:
<tractionCurrentSection id="M58">
<location>
<part idEl="B077/MSBFA" startPos="0" endPos="149.302"></part>
<part idEl="B077/MSBLO" startPos="0" endPos="133.761"></part>
</location>
However I’m getting this:
<location>
<part idEl="B077/MSBFA" startPos="0" endPos="133.761"></part>
<part idEl="B077/MSBLO" startPos="0" endPos="149.302"></part>
</location>
</tractionCurrentSection>
I think the above is putting each part of the list to each part of the list, hence me having 9 children instead of 2 for the 3 attributes I’m updating. Is there a way I can tell the Xquery to group by the list entry instead?
XQuery:
<location>{
for $list in fme:get-list-attribute("_list{}.LCS_CODE") for $Startlist in fme:get-list-attribute("_list{}.Start Meterage 1") for $Endlist in fme:get-list-attribute("_list{}.End Meterage 1")
return <part idEl="{$list}" startPos="{$Startlist}" endPos="{$Endlist}" />
}</location>
A bit of a side second question…. In the example outputs from the customer I have the XML for the “part” element will just end /> (below), which is what I have put in the XMLUpdater (<part idEl="{$list}" startPos="{$Startlist}" endPos="{$Endlist}" />) but my output seems to be ></part> after my attributes, does this matter? I’ve been given a specific XSD to follow.
Example desired output
<location>
<part id=”D202/DEBLO” startPos=”0.00” endPos=”158.44”/>
<part id=”D203/DEBLO” startPos=”0.00” endPos=”130.77”/>
<part id=”D204/DEBLO” startPos=”54.98” endPos=”1097.19”/>
</location>
My current output
<location>
</location>
As a bit of background info this is part of a larger project where I have been given a rather massive XSD to map several of our GIS and Excel datasets to, this is just for one particular dataset. As I say I’m totally new to XML and have read through the W3 schools info to get a bit more acquainted but if anyone knows any other FME-XML specific resources it’s appreciated!
Thanks in advance!
Best answer by takashi
Hi @stephstedman, nested for statements would cause such duplication. Try this expression instead.
<location>{
    let $s := fme:get-list-attribute("_list{}.Start Meterage 1")
    let $e := fme:get-list-attribute("_list{}.End Meterage 1")
    for $code at $i in fme:get-list-attribute("_list{}.LCS_CODE")
    return
    <part idEl="{$code}" startPos="{$s[$i]}" endPos="{$e[$i]}" />
}</location>
Alternatively you can also generate your required result using just an XMLTempleter without using the XMLUpdater. This workspace example contains Plan B and Plan C that demonstrate the way.
tcs-to-xml-sample-2.fmwt (FME 2019.1.1)
Hope this helps.
  • Jan 17, 2020 11:59 PM UTC
<location>{
    return
}</location>
Hope this helps.
stephstedman
  • Jan 20, 2020 1:23 PM UTC
<location>{
    return
}</location>
Hope this helps.
That's perfect, exactly what I needed it to do.  Thanks so much for your help @takashi
Hi @takashi, I have a similar question about the XMLUpdater. I want to get the following xml output:
<group id="X" category="line">
<section id="A">
<section id="B">
<section id="C">
</group>
I have created the following list using listbuilder grouping on ID and CATEGORY attributes: _list{}.CODE
In the XMLUpdater I have input the following parameters:
Group Update Features By: ID and CATEGORY
Update Type: Replace
XML Path: //group
Value Type: XML/XQuery
Value:
<group>{id="fme:get-attribute("ID")" category="fme:get-attribute("CATEGORY")"
for $code in fme:get-list-attribute("_list{}.CODE")
return
<section id="{$code}"/>
}</group>
However, this does not seem to be working. Can you please have a look and let me know if I am missing something?
Thanks,
  • Jan 22, 2020 1:14 PM UTC
 <section id="A">
 <section id="B">
 <section id="C">
 </group>
XML Path: //group
Value:
 return
}</group>
Thanks,
Hi @aquamarine, close, but wrong. Try this expression and take a closer look at what is different from your expression.
<group id="{fme:get-attribute("ID")}" category="{fme:get-attribute("CATEGORY")}">{
    return
}</group>
HI Takashi
Thanks I see I had some issues with the syntax. I have now fixed that but I am unable to get the content in the XMLUpdater to replace that in the XMLTemplater. Perhaps I have the Update Type and/or XML Path incorrect?
This was the code in the original XMLTemplater:
<base xmlns:xsi=http://www.sss xmlns:rsml=http://www.sss xmlns=http://www.sss>
<group id="{fme:get-attribute("ID")}" category="{fme:get-attribute("CATEGORY")}" level="" name="" description="">
<section id="{fme:get-attribute("CODE")}" localStart="" category="" level="" name="" description="">
</section>
<group/>
</group>
</base>
Thanks
  • Jan 22, 2020 3:02 PM UTC
HI Takashi
</section>
<group/>
</group>
</base>
Thanks
Unfortunately the template expression causes an error so cannot test the subsequent XMLUpdater. Please post a correct expression.
actually the XMLupdater does work now. I didn't fix the syntax properly the first time.
  • Aug 31, 2021 2:24 PM UTC
<location>{
    return
}</location>
Hope this helps.
Hi, Can you share the tcs-to-xml-sample-2.fmwt as I am trying to do something similar. Thx
kailinatsafe
Forum|alt.badge.img+24
Hello @sdave​ , tcs-to-xml-sample-2.fmwt should be available in Takashi's comment now. Best, Kailin.
