How to trim leading and trailing forward slashes from a string?
  • Dec 20, 2022 3:55 PM UTC
  • 221 views
aaron
Forum|alt.badge.img+12
I'm trying to use the AttributeTrimmer to trim forward slashes from the beginning and end of a string (e.g. - /SomeText/) but I can't find the correct escape character. Thought it was a backslash. Who knows what I need to use to trim /SomeText/ to SomeText? (FME Desktop 2020.1.2.1 - build 20624).
Thanks,
Aaron
  • Dec 20, 2022 4:02 PM UTC
No escape character should be necessary, you can simply use / as the trim character.
aaron
  • Dec 20, 2022 4:36 PM UTC
Confirmed. Thanks @david_r​ . That's what I tried initially - or thought I did. Must have made a misstep somewhere. Thanks again!
Aaron
