How to: Transposing/concatenating problem.
  • Jan 28, 2022 11:54 AM UTC
  • 85 views
Can't wrap my head around the following reformatting problem. My data looks like this:
Pointid substance1 substance2 substance3...
1 value
2
3
I have a lot of columns in the original data, almost 200 different substances. I would like to achieve the following structure (below) where Substances attribute contains all values of 200 substance columns and is exploded for each Pointid. So basically every Pointid is replicated for each substance and values column have the value of each substance. I've tried multiple combinations of transformers but without result.
Pointid Substances values
1 Substance1 value
1 Substance2 ...
1 Substance3
2 Substance1
2 Substance2
Best answer by nielsgerrits
I think you can solve this with an AttributeExploder.
Attached sample workspace.
AttributeExploderSample
nielsgerrits
Forum|alt.badge.img+67
nielsgerrits
  • Jan 28, 2022 12:14 PM UTC
  • Jan 28, 2022 1:12 PM UTC
Hi @japeki​ , alternatively you can use the ListPolulator to populate all the values of Substance* attributes into a list attribute.
listpopulator-example
  • Feb 15, 2022 1:18 PM UTC
This seemed to work thank you! I've tried AttributeExploder before but somehow didn't get the same result.
