How to transform CSV to Turtle (.ttl)
  • May 1, 2022 12:36 PM UTC
  • 8 replies
  • 657 views
Hi, I have a specific use case to solve. Transform a CSV file to a Turtle file (.ttl).
Here is an example:
CSV file has:
 12345, Fred, 2020-01-01, "Foo, Bar"
    I would like to then transform this row to:
 <http://example.com/12345> rdf:type owl:NamedIndividual ;
                 a:name "Fred" ;
                 a:date "2020-01-01";
                  a:ref "http://example.com/Foo",
                             "http://example.com/Bar" .
And then repeat for all the lines in the  CSV.
Any help appreciated
Best answer by hkingsbury
Thanks - that is very helpful and I got most of it to work...
Two edge cases:
  • can I detect an empty value (ie no value between the commas) and ignore the new line?
  • how can I check if a value like "Foo, Bar" has a comma in-between and create two output lines with each value?
Hey, sorry for the delay in getting back to you.
See the attached template :)
hkingsbury
Forum|alt.badge.img+73
  • May 1, 2022 8:30 PM UTC
Have a look at the StringConcatenator. You can then use the example above as a template and insert the appropriate values into it
 <http://example.com/@Value(id)> rdf:type owl:NamedIndividual ;
                 a:name "@Value(name)" ;
                 a:date "@Value(date)";
                  a:ref "http://example.com/@Value(Val1)",
                             "http://example.com/@Value(Val2)" .
  • May 2, 2022 6:09 AM UTC
Two edge cases:
@riannella​ I really like @hkingsbury​ 's approach - very elegant. An alternative might be to use AttributeExploder that will give you name/value pairs which you could manipulate into the Turtle format. AttributeExploder might be more flexible if your CSV attributes change with each dataset.
hkingsbury
  • May 3, 2022 5:13 AM UTC
Two edge cases:
Can you provide some example data? Often in these situations its best to look at specific data rather than speculate the exact format and behavior of it
  • May 6, 2022 12:50 AM UTC
Two edge cases:
Hi, consider this data:
12345, Fred, 2020-01-01, Foo
12346, Mary, 2020-01-01, "Foo, Bar, Me"
12347, Bill,,
The first line would produce:
                 a:name "Fred" ;
                 a:date "2020-01-01" ;
                  a:ref "http://example.com/Foo" .
The second line:
<http://example.com/12346> rdf:type owl:NamedIndividual ;
                 a:name "Fred" ;
                  a:ref "http://example.com/Foo" ,
                          "http://example.com/Bar",
                          "http://example.com/Me" .
And the third:
<http://example.com/12347> rdf:type owl:NamedIndividual ;
                 a:name "Fred" .
Thanks!
  • May 6, 2022 5:08 AM UTC
Two edge cases:
I also have cases where text like Fred, Mary, and Bill may already be in quotes ("Fred") - so I think I need to remove all quotes (if they are there) then re-add them to be sure.
hkingsbury
  • May 9, 2022 8:09 PM UTC
Two edge cases:
  • May 10, 2022 6:48 AM UTC
Two edge cases:
Many Thanks - that is brilliant !!😀
