How to transform change detector results into the same row.
  • Mar 2, 2023 9:39 AM UTC
  • 54 views
edstrat
Participant
I am having an issue where I want to remove duplicate values from the results of the change detector and merge them all in to a single row to remove duplicate entries. I have provided an example below.
image.pngIf you need more information just ask.
Thanks.
@edstrat​ Use the ListExploder to split your change detector list into separate features.  Then:
  • use a first AttributeCreator to create temporary attribute names for new and old - something like:
_attrName_old    @Value(attributeName) Old
_attrName_new   @Value(attributeName) New
  • Use a second AttributeCreator and Attribute Value... to get the name of the attribute from the attribute value you created above:
  • Use Aggregator with Group By (with your unique record id) to bundle everything back together
If you comfortable in Python you could do this in a short PythonCaller script since FME list attributes and python attributes work well together - see the PythonCaller section at the bottom of is article.
