I am basically doing AttributeValidation but am looking to find values that are blank or empty. Looks like I can't look for blanks or empty's within the AttributeValidation transformer. So, right now I have a testFilter that is checking each field if it is blank or empty. I am using a TestFilter because then I can specify each of the fields that I want to be checked. The problem is that if one record goes through the tester and on the first test we find out that field is blank, then I believe that same record will not go through the rest of the tests. I need to know each field is blank, not just the first one. I am looking for a suggestions on how to do this efficiently.
I am basically running a QC process on a large dataset. We have a bunch of business rules that need to be followed. So I am setting FME up to check all those rules. If a rule is broken, then an email will be sent to the person that introduced the error and then they can go back and fix the error.
So this one step is looking for fields that were left as blank or spaces so that the data editor can go back and change them to NULLS.
