How to Split the attributes based on count and insert it into Oracle
  • Jul 11, 2019 11:16 AM UTC
  • 82 views
I have FGDB file with 200 attributes. But i want to split the parts and insert them into oracle table.
Split 1 : First 70 (1-70)insert into oracle.
Split 2: Second 60 (70-130) records insert into oracle.
Split 3: remaining all are insert into oracle.Here the oracle tables are different.
I need the suitable solution for this.How can i do this by using FME workbench. In real time data there are lacks of records are there we need to insert step by step.
  • Jul 11, 2019 11:44 AM UTC
Do you mean 200 records or 200 attributes? If it's 200 records, then you can use a Counter on your source data and then split it to three different destinations in a TestFilter according to the count attribute. Count<70, count>130, Else.
